Gmax, Windows 10 & 11 compatibility (crash on startup)
kat · 1 · 34166
Although quite long in the tooth now Gmax can still be used to mesh content for various games (in particular Flight Simulator 2002 and Flight Simulator 2020), although a few additional steps may necessary in between. With that said, for Windows 10 and Windows 11 there may be some compatibility issues to contend with that crash the application on startup. The likely cause of this is the Gmax using the wrong viewport driver to render content, that's the HEIDI (software), OpenGL and Direct3D (hardware) selections typically accessed from Customize » Preferences » Viewports - Display Drivers, which can't then be accessed and changed. When this happens a workaround can be used to add a 'flag' to the Gmax shortcut forcing the gmax Display Setup dialogue to appear so the correct option can be set.
To set the flag, right-click the Gmax Desktop icon and select Properties. In the Shortcut tab, append " -h" (note the space before '-h') to the Target: file path e.g.;
"D:\Program Files\gmax\gmax.exe"
Becomes
"D:\Program Files\gmax\gmax.exe" -h
Optionally, for Windows 10 and Windows 11 set the Run this program as an Administrator checkbox in Compatibility options.
Click Apply then OK to close, then restart Gmax. The gmax Driver Setup dialogue will appear. Set an option; HEIDI, OpenGL or Direct3D (HEIDI is initially the safest to verify the application starts and no other issues are in affect). Once the application starts up correctly the driver can be changed if needed in Customize » Preferences » Viewports - Display Drivers and the shortcut flag removed.
IMPORANT: the likely cause of the issue is the version of OpenGL Gmax uses to drive the viewports, which is obsolete or incompatible with the latest versions of the API. This is especially so for AMD powered graphics systems - setting OpenGL as the driver typically won't work so the driver should be Direct3D (hardware) or HEIDI (software).
Setting the Desktop shortcut flag to force gmax to start in 'safe mode'.
With the Desktop shortcut flag set the gmax Driver Setup dialogue appears with three options; HEIDI, OpenGL and Direct3D - HEIDI is the safest.
Gmax open and running on Windows 10 once driver is correctly set
