[3DVia Shape] Publication Failed. Unknown Server Error: 500
Started by kat, March 11, 2010, 06:57:09 AM
When publishing a model, scene, or object to your 3DVia Shape account the following error message appears;
Publication Failed
To fix this and publish your work to the network do the following;
Click the "[b]X[/b]" top-right of the application to close it, this will bring up a dialogue box asking what you want to do. Of the options available click "[b]Later[/b]" to save the file locally. Next time 3DVia Shape is started you'll be presented with a selection dialogue listing any scenes saved locally. Select the correct file to open it into Shape and then re-publish.
The error occurs usually as the result of a long work session, you've basically timed-out the connection to the Via network so in order to publish the file the app has to be closed, reopened and you log back in.
Users of Windows Vista will find the temp file in the following location;
QuoteC:\Users\[username]\AppData\Local\DassaultSystemes\CATTemp\3DVIAShape
With the file extension *.tmp.
