Compiling with -Patchshadows
kat · 1 · 39194
Can someone explain me how to compile with -patchshadows on? Where and how do I execute / add this option? [BNA]
Assuming you don't want to go for a full out "let's go into DOS and compile the thing", then I suggest you either create a new bsp menu option, or modify the existing ones. This can be done using the project settings on the file menu. However, if i remember correctly, there is a line limit in the edit box, which truncates even the default ones, so you might have to open the project file up in notepad or something similar, and just add a new line there. If you study some of the existing ones, you are sure to understand the format. [djbob]
additional note: I had to add the -patchshadows option manually in Q3Radiant because of that line limit, but in GTK 1.1.1 using the built in editor seems to work just fine. [pjw]
