LoadTGA: Only type 2 (RGB), 3 (gray), and 10 (RGB) TGA images supported
kat · 1 · 20909
I have the following compile error after loading the shaders :
********* ERROR ***********
LoadTGA: Only type 2 (RGB), 3 (gray), and 10 (RGB) TGA images supported.
How can i find out which tga-file doesn't fit ? [Strahlemann]
it's quite possibly not a *.tga at error here but more likely you've got a *.jpg in your working directory that's been saved with progressive compression which Q3 doesn't like... re-save the image without and you should be ok... [anon.]
