ProblemAre there some unwritten rules concerning the making of portals? I have had to simplify the portal I made for my WIP considerably just to get it to compile. It appears that a portal's geometry cannot go beyond a certain level of complexity, nor can it be too large (i.e. the size of the world or larger). I got the...
MAX_LEAF_FACES... error in the BSP stage when I attempted to construct some buildings from brushwork in my portal. I've now just made a few simple buildings, ASE'd them and cloned/rotated them, and there's no problems. Has anyone had this error before? What's the different between a BSP leaf's face and its portal? [seremtam]
SolutionThis error occurs when you have too many drawsurfaces in a single BSP leaf. The max is 0x2000 (8192). You must have some exceedingly complex set of surfaces or are not using q3map_nonplanar or meta to merge stuff, or using _blocksize with a value too high or simply not splitting them map up enough.
I don't recall the last time I saw anyone get that error. [
ydnar]
Additional note: or your skybox area is too complex. Try to keep it reasonable, because the 8192 leaf/surface max means you're limited to 8192 surfaces in your skybox. Usually less, since sky leaves tend to have other surfaces already in them.
