Unable to find default tag file [path]/shadertags.xml. No tag support
Started by kat, June 25, 2015, 05:05:01 PM
0 Members and 6 Guests are viewing this topic.
GtkRadiant 1.5 has a common problem that's thankfully relatively easy to fix. On starting up the editor a quick look at the console will reveal the following error message in red letters;
Unable to find default tag file [drive://directory/path]/shadertags.xml. No tag support
Assuming the error isn't popping up as part of the wglMakeCurrent error, do the following;
  • Go to the"Plugins" menu
  • And select "ShaderPlug ยป Create tag file"
This will create the missing shadertag.xml file in your 'user' folder (C://users/ for Windows Vista) and tell you to reboot. On doing so the error message will now be gone.
