[blender] graph editor insert keyframes?
is it broken in 2.69? ...i haven't used it for a while, but i vaguely remember it just subdividing the selected curves using an average value between the nearest keyframes ...but in my latest project it's spiking the graphs with what appears to be random values at the current frame/cursor, as it cuts through the curves.
If you're using an RC then check the bug-tracker to see if there are any bugs or issues related to that (assuming it's not an intentional change). Check 2.68a or whichever 'live' version of Blender you have available, so see if the problem is there. If not you'll likely have to scour BlenderArtists to see if anyone has posted on it.
thanks kat, i'll re-install an older version and test it... at the moment i would say it's a bug as it seems inconsistent.
