Author Topic: Rendering difficulties  (Read 4614 times)
« on: March 12, 2012, 05:39:05 AM »
I'm finding that I cannot seem to view any of my blender models while actually in Blender.
Whenever I try to use RENDER, it shows a hideously poor renditon of the model, and it won't even show the proper textures applied to any of the parts. See the example below....
The object on the left is the original model, while the one on the right is a re-imported LightWave object. Neither one seems to work while in Blender.
When I export the model to a Lightwave object, however, it looks fantastic when I import it into another program, like Terragen, but it just won't work for me in Blender itself. Even if I try re-importing said LightWave object back into Blender and try to render that, it still won't show it properly.
I've found the only way I can check the results of my work is to export each phase of my model as a LightWave, import that into Terragen, and then examine it in there....what a huge pain in the ass!
What is going on, and how do I fix it?
Thanks, Dave
Re: Rendering difficulties
« Reply #1 on: March 12, 2012, 10:46:32 AM »
Check list;
  • You should have the usual "Material", "Texture" and "Image" slots (which you have otherwise you won't see anything in the 3DView)
  • Check the "Map Input" settings are all set to "UV" (F5)
  • Check the "Map To" values are set to "Col"
  • In "Texture" properties, check the "Source:" info (the path to the image) is set to "Relative" or the image is actually being loaded properly - missing textures in a proper render is usually indicative of Blender not being to locate the image
  • Check that Blender isn't using a 'cached' version of the image - save the file and re-open it, the images should remain in the scene (else everything turns pink)
Try the above and see if that helps. Also, try rendering a completely new scene to see if the same thing happens there - just use the default cube and apply a material/texture/image combo, then render.
« Reply #2 on: March 13, 2012, 08:52:48 PM »
Nothing, no difference. I did change the one thing, "Map Input" to UV (it was previously on orco), "Map Output" was already on Col, and I can't find this "Texture" properties that has a "Source" menu on it, so I couldn't do anything about that.
However, whenever I unwrap an object for applying, and load the image into the UV editor, or use the texture buttons to load my texture images, it always lists the proper directory that I'm drawing my images from.....and once again, whenever I export to another program, the image is pristine over there.
Where do I find this "Texture" properies with the "Source" choice? I've looked under the Materials button, the Textures button, the File Paths of the "I" screen up top, and selected the closest thing to a "relative" button I can find there, the "Relative Paths Default". I've tried changing the //textures entry to the direct path where my images files are stored in to no effect.
I tried applying an image to the simple start-up cube of a new file, and that still doesn't work. The render still just shows a plain gray cube, even though the 3D screen shows the image on it. I'm stumped, and getting terribly dissapointed in Blender....
« Reply #3 on: March 13, 2012, 09:18:04 PM »
If you want to (or are able to) email me the file I'll have a look and see what's going on.
RSS Copyright © 2021 KatsBits™. All Rights Reserved. No part of this or associated properties shall be reproduced without prior consent. AdvertisePrivacy PolicyDMCA (about DMCA) • Copyright PolicyCopyright Contact Home Blog Support About Contact Site Search Site Map RSS feed Forum YouTube FaceBook LinkedIn Twitter Instagram IMVU
