Help with (Blender) export hair mesh to IMVU - Hair
Offline carly1717
  • Workshops: IMVU
Hi, I watched 3 videos (including your video) on how to mesh hair from blender to imvu, but none of the ways seem to work!
I just need to know if I'm doing something wrong because i rigged it and everything but when i try to put into creator app it just make avatar appear bald!
That seems like the mesh could just be inside out. A quick way to check is to enable the "Two-Sided" setting in IMVU - if the mesh appears it just means its surfaces are inverted in Blender, an easy fix (see here if using Blender 2.8+). Would really need to see screenshots of what you're looking at in Blender and then IMVU though to rule out other potential issues.
Offline carly1717
  • Workshops: IMVU
okayyy! once again, you have helped me... thank you so much, now I just have to re watch the rest of your video for positioning the mesh! Thank you so much!!!!
