[blender] animation question
Offline Shaderman
Hi,
I have an armature with 5 bones mounted to it.
I'd like to rotate the armature around the y-axis...
but keep the initial transform of all mounted bones (Bone0 in this picture):
I know I could adjust every bone for every animation step of the armature, but I hope there's an easier way to do it (maybe some switch in Blender) :)
Any ideas?
There is... but you can guess what it means doing. You'll need to set up sets of control/target bones that use different types of relationships that then usual parent >> child. Personally I'd just do it the way you described; unless this were a series of objects that needed special anims I'd look towards a 'targeted' rig, but for something that simple it's not really worth the time if you['re just wanting to "git 'er done" - it'd probably take just as long to set up the complex rig as it would to just knuckle down and keyframe animate it.
Offline Shaderman
Thanks kat, I hoped there was a simple solution. Now I did it my way (© Frank Sinatra) :)
I haven't done any animation work for a couple of years but iirc we can set up one bone's keyframes and then copy and paste the size/rotation/location curves from the ipo window (if they still have that?) to other bones or objects.
Offline Shaderman
Thanks ratty, that sounds like it could work but it's too late now :)
I've completely remade that "model" because I found a much better solution for what I need. This thing is used in a game prototype and I think I can tell more about it soon... I should get out my other project first :)
@ shaderman, cool and I'll be interested to see what you've been working on.
