[MD5] animation issue in Blender 2.56a
Offline motorsep
I don't know if it's the exporter or what, but my animation comes out borked :/
Here is the video of the animated model in-game:
http://www.youtube.com/watch?v=NstVKxqHj_A
Here is .blend file:
http://www.pasteall.org/blend/4963
Can the exporter guru look at it and see what am I doing wrong, if anything?
Thank you.
Simple as that is, that's a nice bit of rigging you've got there you know. Anywho I loaded this up into 2.56a had a look and then just exported it as is. To check the animation I loaded it up into the MD5 model viewer and couldn't see any of the nasty wobbling shown in the video. The only reason I can think it *may* do that is because you've not keyframed strategic points along the timeline - it's been my experience that Blender has always had issues with cyclical sequences that you often have to keyframe around to force proper rotations.
[EDIT] split topic and moved to content section.
Offline motorsep
Apparently a modern algorithm has been implemented into Darkplaces engine. For some reason the animation playback is acting up with IK bone with a mesh being directly attached to that bone.
So I just created a copy of the IK bone and set Copy Location and Copy Rotation constraints to it from the IK bone. Then I attached vertices of the mesh to that new bone. Problem solved  ;)
I know it doesn't sound too clear, but the tutorial might be coming soon ;)
Couldn't you set the rig up so the IK bone is connected as a 'helper' rather than a part of the main rig to which verts are weighted?
