IMVU Studio - normal maps
kat · 1 · 21786
One of the more advanced features coming to IMVU Studio when its released later this year, is the ability to use NORMAL maps. The following is a basic breakdown using Blender 3D to illustrate what normal maps are, how they work, and how to create them.
Important: in relation to texture making and content creation in general, making normal maps does require a more advanced skill set to make and work as expected.
Normal map slot in IMVU Studio
The normal map slot shown in the proposed IMVU Studio, here title "Normal" (highlighted red above).
What is a Normal Map
At their most basic normal maps perform two functions, they; 1) give the impression of surface detail or structural complexity; and 2) they augment the way objects might shade and shadow in response to lights and illumination. Generally speaking they are 24 bit RGB bitmap images that exhibit a distinctive blue-ish-purple hue and are used as non-colour textures within existing materials - for IMVU Studio this is the "Normal" slot (shown above).
Design note: normal maps are typically not used to provide 'colour' information, i.e. what the user might otherwise recognise as the patterns that define whether something appears to be brick, denim, lace etc.
Normal maps are not always immediately noticeable
The effect normal maps create is not always immediately noticeable and can be quite subtle depending on the mesh, what's depicted and image resolution - careful or careless texture design can often highlight or obscure the effect of normal maps.
How do Normal Maps work
Without getting too technical, normal maps work by interpreting RGB (Red/Green/Blue) colour values as surface detail. This is possible because the colours associated with each pixel of an image, a 256x512 for example, represents a direction, the orientation a corresponding face is pointing, which essentially results in the impression of detail or structure that isn't actually present on the avatar.
Design note: normal maps don't create 'height' or 'depth' per se but that's often the impression given due to what is typically being represented, i.e. features perceived as having height and depth.
Normal maps use object UVs
Normal maps generally conform to the UV map of the mesh they are created for so they can do their job of emphasising features that might be painted on the 'diffuse' or 'colour' image the user sees, the MCG elements for example (although not shown above - see below).
How are Normal Maps made
Generally speaking there are two ways to make normal maps; 1) from high resolution meshes, and 2) the conversion of a greyscale image.
Design note: the first can be more challenging to make but tends to produce better results, the latter is easier but prone to more 'user error' inaccuracies.
In practice this means the first approach needs a high and low resolution version of an object, the latter being UV mapped and textured. The two are positioned in the same place and 'baked', that is, the surface and structural detail of the high resolution mesh is transposed into pixel data that's written, 'baked', to the image mapped to the UV's of low resolution mesh. This is then saved as a bitmap for use.
Design note: IMVU content, clothing in particular, presents a particular challenge with respect to normal maps due to the detail required of the mesh when baked or converted, and the amount of texture space available (number of pixels available) when servicing underwear, lace and other fine detailed items. This may oblige rethinking the way certain products are produced.
Baking normal maps from hig resolution meshes
For best results, especially when working with relatively low resolution textures, normal maps are 'baked' from high detail, high resolution meshes to the UV's of the low resolution game mesh - depending on the item, mesh resolution will vary, shown above the resolution may be sufficient for the avatar but not the MCG detailing (which would require far more mesh structure to be made to accommodate the straps and waist).
For the latter, normal maps can be generated from an image, a greyscale 'template' of sorts comprising tonal values black through grey to white, black being 'depth', white being 'height', each tone then being converted into a normalised RGB colour value. The converted image can then be saved, ready for use.
Tools: nJob (stand-alone); GIMP filters - normalmap, insaneBump; Photoshop filters - nVidia (or directly).
Creating a normal map from an image
Normal maps can also be created from greyscale images that are specially made to be converted - black equates to 'depth', white 'height'.
The avatar is shown first without normal maps then with normal maps (the again without) to show the comparison between the two states - avatar is skinned in white for clarity/normal maps are only assigned to body and head.
Resources
Download example files (*.psd & *.tga images).
How NOT to make normal maps.
Bake tiling normal maps.
Bake normal maps from meshes.
