IMVU joining armatures in Blender (2.45/49)
kat · 1 · 15145
Because using 'units' helps to make moving things around easier, the armatures from each unit will need connecting into one main Armature object. Select each armature then either re-select the 'root' section or click on that last so it's highlighted brighter pink; Shift+J to join sections.
