Game Editing => Q3Map / Q3Map2 Compile Errors => Topic started by: kat on June 25, 2015, 10:18:47 PM
Title: RE_LoadWorldMap: maps/[mapname].bsp not found
Post by: kat on June 25, 2015, 10:18:47 PM
I got...
RE_LoadWorldMap: maps/testctf1.bsp not found
(testctf1 is the map name) anyone got a clue on this one? I followed a Q3 Radiant manual and did exactly as it said (even in the sample map) and it did not load in Quake 3. [MEtAL]
You tried 'sv_pure 0'? Did you put the map file into a pk3? If not try that as I seem to remember someone saying pk3 files have preference over folders/files in baseq3 (the game will look at pk3 files 1st) Also make sure you have an info_player_start [kat]
