General Category => FAQ on games, gaming & IT => Topic started by: kat on August 14, 2023, 12:42:01 PM
Title: Blackberry Hub doesn't comply with Googles secure browser policy
Post by: kat on August 14, 2023, 12:42:01 PM
Blackberry Hub gmail error
When using Blackberry Hub to manage Gmail emails the following error may occur when setting up an account;
QuoteAccess blocked: authorisation error.
You can't sign in from this screen because this app doesn't comply with Google's secure browsers policy. If this app has a website, you can open a web browser and try signing in from there.
The error occurs intermittently, and depending on the device used, age not necessarily being a factor.
Instead of using the 'auto-setup' feature provided by Blackberry Hub;
If the account is still blocked make sure 'IMAP' is enabled in Gmail (https://support.google.com/mail/answer/7126229?hl=en#zippy=%2Cstep-check-that-imap-is-turned-on), and/or try swapping the Security type options between SSL/TLS and STARTTLS (with or without 'accept all certificates') for both incoming and outgoing mail.
