For blend 2.8 I made a holster(for female). I am attaching it to the hip bone but fail once I get into imvu.
I call it an accessory, import the fbx, apply scale... but I have no idea what to put into the Base plate for a number so it is just floating up by the head.
Can anyone help me with the correct Base plate number for a female hip attachment?
The Mesh ID for female accessories is 2 (https://www.katsbits.com/codex/imvu205/). If it's to be matched to the Hip, once you have the FBX imported and set up (textured etc), go to the config tab and change the Attachment Node information to lfHip (or rtHip). That should make the mesh jump to where it should be (Apply Changes obviously).
