General Category => FAQ on games, gaming & IT => Topic started by: kat on January 15, 2013, 03:11:25 AM
Title: Device Manager & USB not recognising Blackberry Playbook
Post by: kat on January 15, 2013, 03:11:25 AM
When plugged in to an available USB socket, neither the computer nor Blackberrys Device Manager recognise the presence of the Playbook.
Assuming there isn't a fault with the USB socket on the PC or the Blackberry Playbook, nor an issue with the cable used to connect the two together, try the following first;
(typically "Device Manager" can be found by right-clicking "My Computer/Computer" and selecting "Properties")
Additional Troubleshooting
From the computer the Blackberry is plugged in to, open "Device Manager" and check the "Universal Serial Bus controllers" listings. For each "USB Root Hub" entry, check the "Power Management" settings to make sure "Allow the computer to turn off this device to save power" is UNchecked (disabled).
When the Playbook is plugged in it's recognised as a Network Device and then 'mapped' as an external HDD, rather than being an additional storage device like a USB flash drive. This means there should be an entry in "Network Connections" that can be checked.
