General Category > News
[FIXED in 2.59] Blender 2.58 .map exporter broken
<< < (2/2)
motorsep:
That's not really the point of that exporter. You can have any kind of mesh in your scene, and it will be correctly exported as brushes. You can have convex and concave meshes and the exporter will figure it out and split brushes properly. It will also caulk insides and set texture of the outside face to whatever shader you set.
kat:
Quake MAP exporter is still broken in the new 2.58.1 release of Blender, this time with a different error. Unlike previous, the error happens regardless as to what state the scene is in so un/textured surfaces err out regardless.;
--- Code: ---Map Exporter 0.0
        writing cubes from meshes
  File "D:\Program Files\Blender Foundation\Blender 2.58a\2.58\scripts\addons\io
_scene_map\__init__.py", line 74, in execute
    return export_map.save(self, context, **keywords)
_scene_map\export_map.py", line 470, in save
    export_map(context, filepath)
_scene_map\export_map.py", line 346, in export_map
    elif is_tricyl_facegroup(face_group):
_scene_map\export_map.py", line 215, in is_tricyl_facegroup
    if len(f) == 3:
TypeError: object of type 'MeshFace' has no len()
--- End code ---
mikshaw:
The new Blender 2.59 changelog lists bug fixes in the map exporter.  Maybe it'll work for you now.
kat:
Woot.. tiz fixed  8)
kat:
Broken in 2.60. Simple mesh objects export OK, anything with a texture applied doesn't and produces the following;
  File "D:\Program Files\Blender Foundation\Blender 2.60\2.60\scripts\addons\io_
scene_map\__init__.py", line 104, in execute
scene_map\export_map.py", line 485, in save
scene_map\export_map.py", line 342, in export_map
    write_cube2brush(file, face_group)
scene_map\export_map.py", line 71, in write_cube2brush
    if uf and uf.hide:
AttributeError: 'MeshTextureFace' object has no attribute 'hide'
--- End code ---
