Author Topic: [doom3.gpl] Change name of Doom3.exe  (Read 1560 times)
« on: July 08, 2016, 06:50:03 PM »
The better way to change the name of the *.exe produced by compiling doom3.gpl is to modify the compiler output so it writes the name(space) correctly - changing the program executable or shortcut is possible but not the correct approach to use, neither is renaming any part of the project Visual Studio's Solution Explorer (in relation to naming the *.exe this does nothing, it only changes the name of the Solution project).
Changing the name of 'projects' in the Solution Explorer don't effect the name of the executable
To correctly change the exe name, in the Solution Explorer;
Step 1
  • Under "exes" right-click "DoomDLL" to open "DoomDLL Properties Pages".
  • Expand "Configuration Properties" (if not already expanded) and select "Debugging".
  • To the right of "Command" (not "Commend Arguments") click "$(OutDir)DOOM3.exe" to highlight for editing, replace "DOOM3" with the name of choice, e.g. "Catacombs" - string should read "$(OutDir)[custom name].exe", i.e. "$(OutDir)Catacombs.exe".
  • Click "Apply", then optionally if not continuing to 'Step 2', click "OK" to exit the Properties Page manage.
    Set "Configuration Properties Debugging Command" to rename the executable
Step 2
  • Expand "Configuration Properties" if not already visible, expand "Linker" then select "General".
  • To the right of "Output File" select "$(OutDir)DOOM3.exe" to highlight for editing, replace "DOOM3" with the name of choice, e.g. "Catacombs" - string should read "$(OutDir)[custom name].exe", i.e. "$(OutDir)Catacombs.exe".
  • Click "Apply", then "OK" to exit the Properties Page manage.
    Change "Linker" properties to reflect the name of the executable to be compiled
Other useful doom3.gpl topics
- Compiling doom3.gpl source code using Visual Studio
- Changing the Doom3.exe shortcut & program icon
RSS Content is copyright © KatsBits™ 2017 unless otherwise stated. All Rights Reserved.
No part of this web site may be reproduced (except for personal use, or otherwise stated) without prior written permission from KatsBits.com. For more infomation on copyright click here.
Web design cpdtAdvertisePrivacy PolicyDMCA (about DMCA) Home Store Workshops Blog Jobs Support About Katsbits Contact Site Search KatsBits Help Site Map RSS feed Forum Old Forum YouTube FaceBook LinkedIn Twitter IMVU
